Is there a procedure "Out Of The Box", "Custom" or "Third Party" that gives the ability to import an excel spreadsheet (that is formatted to map to Vault Pro) into Vault that will either create new items (parts or assemblies) or search and find existing items (parts or assemblies) and then structure these items (parts or assemblies) into a BOM in Vault Professional?
The attachment below is an example used in PTC Windchill and I'd like a comparable version for Vault Pro.
Thank you
Hi r.smith1
Thank you very much for the link. This should be very helpful.
Once the items are in Vault, can a spreadsheet then structure these items into a Bill of Material or would this have to be a manual process?
Do you have any examples of these processes (Importing items into Vault) and (Structuring the items after import into a Bill of Material)?
Thank you
An Excel spreadsheet brought into Vault is still just a spreadsheet. I don't know of any way to suck it into a BOM in that form. I would love it if someone would tell me I'm totally wrong. 😄
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Hi r.smith1
That sounds like what I'm asking for...Thank you
Could you elaborate on this subject a little further...
Would you be able to provide an example of the structure Vault would require for this to work properly or a list of the required fields or attributes?
Would you also be able to provide a screen shot on where you import the spreadsheet to the item masster?
I do not see how to do this in Vault.
Sorry for all the questions and thank you for your time.
Hi wshaner,
The link above has an example, however one of the best ways to learn how to do this is to create an inventor assembly if you don't already have one, check into Vault then assign an item. Once you have the item created for the assembly, release and export the Item. Select the property fields in the export wizard that you want to see. Once exported, you will have the perfect template for import and how you will want to set up your spreadsheet for items import.
It's honestly as easy as that!
