I want to create new vault on network file store location , but i have problem. User does not have permisson. How to decide.
Vault 2012 server basic
that looks like you don't have the network permissions to write to that directory
DarrenP
The "impersonization" user (by default "AutodeskVault") needs access to the network share. This means you either need to change it to be a domain user and give it full access to the share in question, or you can create a local user on the machine hosting the share with the same name and password as the impersonation user.
The impersonization user is set in the ADMS-Console under "Tools > Administration > Advanced Settings tab > Advanced Configuration Settings.
But beware that you can only put the filestore on a network share. It is not possible to put the database on a network share - Microsoft SQL will not allow that.
-Dave
