Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
I can't delete link between an item and document
2 REPLIES 2
sato2511
284 Views, 2 Replies
Hy!
I can't delete the link between an item and the document.
I attach image.
Can anyone help me, please?
Thank you!
sato
2 REPLIES 2
mollons
in reply to: sato2511
You can't explicitly remove a tertiary link from the item (unless you are using Vault Pro 2013).
Is the goal to delete the file or just remove it from the item?
Scott Mollon
Quality Assurance
Autodesk, Inc.
Be sure to check out the Vault Help Wiki!
Maxim-CADman77
in reply to: mollons
We are suffering the issue: ALL idws created on members of particular iAssembly (Pack&Go shows that each drawing is definetly created using only ONEmember) are tetrially linked to ALL Items created on members of the iAssembly (no secondary links to other members). Of course those wrong tetr.links could be removed with Vault Explorer 2013 but this is not a solution as they return back on Item update. Does any of you have the same problem? Any ideas on how to solve?
