Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
How To Upload New Part To Vault's Library?
6 REPLIES 6
mmiller1
447 Views, 6 Replies
I've created a part that I want to make a Library part. How do I sign this into the Vault Library? Just "signing in" as normal will put this file in the project's folder in the Vault which is not where I want it. How do I direct it to the Library?
Mike
6 REPLIES 6
in reply to: mmiller1
All you need to do is save (or move) this file to the folder in your working
folder that corresponds to the library folder you want it in... then when
you open this file in Inventor and select "Add to Vault" you should see it
automagically go into that folder.
Brian Roepke
Manager, Customer Success
Data Management
Autodesk, Inc.
mmiller1
Got it! Thanks!
Mike
sbmrnd01
". then when you open this file in Inventor and select "Add to Vault" you should see it automagically go into that folder."
Sorry, may i know where is the "Add to Vault"?
Senthil_Kumar
Add Files-> Check-in
Hope that helps.
Senthil Kumar
Development Manager,
Autodesk, Inc.
Be sure to check out the Vault Help!
sbmrnd01
in reply to: Senthil_Kumar
Thanks.
But I created a series of part using iPart. Am i going to do it for each generated part or there should have better way to upload in batch?
Senthil_Kumar
in reply to: sbmrnd01
If you check-in the iPart factory all the members ( which are Not yet vaulted and Checked out) will be checked in.
Hope that helps.
Senthil Kumar
Autodesk, Inc.
