Dear All,
We have a Vault Professional user, who's KnowledgeVaultMaster_log.ldf with 16G but KnowledgeVaultMaster.mdf is about 100M. other vaults have same problem. their file store totally about 300G, and purge old version every week.
So the question is: Does Autodesk has standard workflow to backup and purge those _log.ldf ?
Any input is appreciate!
Gengyun
Solved by olearya. Go to Solution.
Hey Gengyun,
Running a maintenance plan on your Vault databases (which is advisable in any case) should take care of this - see the details on this in the advanced configuration guide.
Did running a maintenance script on your installation work for you? We have the same issue and I would like to get the size of the log file down as well. Mine is sitting on about 13Gb.
