Hi All,
I have two server.Database is one server and Licesnse is on other server.How to map this two server when i log in vault pro 2015?
Thanks in Advance.
Cheers,
Mari
On the host where you installed Vault Server (ADMS), there is a file in the installation directory (ex: "C\Program Files\Autodesk\ADMS Professional 2014") called "LICPATH.lic". You can edit it with notepad.
If should look something like the following:
SERVER MyLicenseServer 000000000000
USE_SERVER
You can change "MyLicenseServer" to the hostname where the license manager is installed.
-Dave
