Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
How to configure Windows Firewall for Vault Server 2015 Basic?
1 REPLY 1
mechamania
1774 Views, 1 Reply
I have a Client (Inventor) and Server Vault (2015) installed on seperate computers.
I only can login to the Server when disabeling the FireWall on the server. I know this is not a good thing. So how can I configure the FireWall so that is is safe while I can login into the Vault from Inventor?
The Vault server is running on Windows 7 Ultimate (64 bit). The Client (Inventor) is running on Windows 7 Home (64 bits).
1 REPLY 1
mandalt
in reply to: mechamania
For Windows 7
  1. On the Windows Start menu, select Control Panel.
  2. On the Control Panel, double click Windows Firewall.
  3. If the Firewall strip says that "Windows Firewall is helping to protect your computer," then click Advance settings on the left side of the Windows Firewall dialog box.
  4. In the Windows Firewall with Advance security dialog box, click Inbound Rules, located in the left pane.
  5. From the Action pulldown menu select New Rule.
  6. Select Port and click Next.
  7. In the Protocol and Ports dialog box, Enter the following information. Specific local ports: 80
  8. In the Action dialog box select Allow the connection and click Next.
  9. In the Profile dialog box select all the listed profiles and click Next.
  10. In the Name dialog box enter the a name for this new rule. To keep things simple you can call this new rule Vault. Adding a description is optional
  11. Click Finish
The same information in available is the follwing URL:
http://help.autodesk.com/view/VAULT/2015/ENU/?guid=GUID-D77453BD-68A1-465F-8979-05F21E5A382B
Taimur Mandal
Designated Support Specialist
