I backed up the data from the old server with Vault 2012 server and now i want to restore it to my new server with Vault Basic 2014 Server. They both have the same versions of SQL ( SQL 2008 R2). but for some reason when i try to restor the backup data I get an error message saying, " The database or backup is not compatible with the database server. This error may be caused by restoring or attaching files form a version of SQL Server that is higher than the version of your SQL Server". Could somebody please help me. thank you
is the vault 2012 also vault basic or is it Vault Workgroup, Collaboration, or Professional?
DarrenP
Ensure that the SQL for your new server has been patched with the same Service Packs/Updates as the SQL of your old server.
Samuel
I made sure that the SQL versions are the same. I installed SQL 2008 R2. still no luck.
