Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
How can we delete a job that is being processed by a PC that not exists??
6 REPLIES 6
spascual
498 Views, 6 Replies
6 REPLIES 6
in reply to: spascual
There should be a "remove" command from the Job Queue - check the "tools"
menu (I think) in the Vault Client
MaxU77
We have several jobs "sticked" in the queue.
The status is "Processing" but this is definitely the lies.
Buttons "Remove" and "Re-submit" are greyed out.
Is there any method push them on?
PS: Vault Manufacturing 2010 (14.2.71.0)
MaxU77,
AI2011 Certified Associate
(Soft: PDSU2012, VP2012&VP2013)
amasva
Not sure if it will work, but have you tried to disable and then enable the jobserver again?
Asle Martin Svastuen
Autodesk Product Design Suite Ulitmate 2012 Sp1 / Vault Collaboration 2012 Sp1
HP EliteBook 8560w
Intel(R)Core(TM) i7 CPU Q 720 @ 2,0GHz 2,0GHz
16GB RAM
Windows 7 X64 SP1
MaxU77
in reply to: amasva
Thank you for attemp to help.
Yes I've just tried it (pity there is no apply button - hope unchecking JobServer option and close settings window, then opening settings and checking the option counts enough).
Queue hasn't changed.
Any other suggestions?
Maybe I should found and edit some xml file on serever?
MaxU77,
amasva
Open the job server queue and add the button "reset to queue". See attached image. After resetting you should be able to delete the job.
HP EliteBook 8560w
16GB RAM
Windows 7 X64 SP1
MaxU77
in reply to: amasva
Thanks! That helped. I wish I could mark your advice as solution (I believe only topic starter could).
MaxU77,
