I cannot loing my Vault Server. I got the error message:
'HOSTNAME' failed remote authentication to 'HOSTNAME'
It works fine till yesterday. I check the server and found IT dept change the machine name, which I think it's same as hostname. I have to talk with them and got it change back. still not working.
at server, ping IP address, ping hostname, ping localhost all works
at my machine, ping IP address, works, ping hostname NOT
http://<hostname>/AutodeskDM/webclient, I can see the login page. after I click on the Login, got the same error message.
What's wrong? How to troubleshooting it?
Thank you so much.
Wes
Solved by wesbird. Go to Solution.
Solved by jesseck. Go to Solution.
Thank you so much, jesseck.
I also found, Vault Server, is member of Workgroup, NOT Domain. could this be the reason? I don't remember what it was when it works.
I'm not good at network/admin. Thank you for your help
Wes
Hi Jesseck:
I ask our IT to add HOSTNAME to dns server, now I can ping HOSTNAME from my machine. when I try Vault client and webclient at server, still the same error message
Any idea what could go wrong?
Thank you so much
Wes
Try running the ADMS Server Console diagnostics from the server itself... that will help figure out if there is something on the back end. The Vault logs, specifically the Filestore log and v-log, will help point out problems as well. Now that you can ping from your client, can you connect to Vault?
Thank you, jesseck:
I found
Error: Soap Exception ( mesg-id = 635387328548880601 )
Exception: SiteSigninError [8004] (BJCVAULT, BJCVAULT)
in the vlog, and google it,
http://crackingthevault.typepad.com/crackingthevault/2013/12/sitesigninerror-8004.html
follow instruction:
1. Delete SiteConfiguration.xml from C:\ProgramData\Autodesk\VaultServer\Configuration
2. Perform an IIS reset.
3. Try your command again.
it works.
wes
