Hi
I got an error in vault 2013 upgrade from 2012.
our System Configuration is :
OS: Windows server 2008R2 SP1 (x64)
SQL Server: SQL server 2008R2 SP1 (x86)
it is a dedicated server for Autodesk vault.
We had Vault 2012 installed on the server.
As per the ducumetation I started the 2013 installation without uninstalling 2012 version.
7 out of 8 steps in installtion went ok.
The Error I got was Error 29001.
I am attaching the screen capture of the error and the setup log file also.
Any help is greatly appreciated.
Regards
Lalit
Solved by Lalitkmr123. Go to Solution.
i found this: http://crackingthevault.typepad.com/crackingthevault/2012/11/error-29001-install-error.html?utm_sour...
DarrenP
DarrenP
Thanks for your reply. The issue was fixed . It had something to do with ASP version in IIS. Reinstalled IIS in server manager roles as shown in advanced configuration guide and it went OK.
Thanks again.
Regards
Lalit
