Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Getting latest version of idw from command line
8 REPLIES 8
Message 1 of 9
kevin
194 Views, 8 Replies
Hi
I am looking for a command line prompt that will enable me to get the latest version of idw's from vault from DOS.
I am looking to do a batch "get latest version" of all parts and assemblies based on the BOM in an inventor assembly - which I can already get into exel - without the tedious operation of having to individually sift through Inventor explorer and select in task scheduler.
8 REPLIES 8
Message 2 of 9
Madhan_T
in reply to: kevin
Could you please let me know if you have issues with getting latest version on the TOP level assembly from VE or from Task-scheduler. Actually, this would download all sub-assemblies and parts. Perhaps, I may have misunderstood the exact requirement. I would be glad to help you if I understand this better.
Madhan
Madhanagopal Thiruvenkatachalam
Principal Engineer
Engineering Escalation Team
Autodesk, Inc.
Message 3 of 9
kevin
in reply to: kevin
No problem getting latest versions of all parts and assemblies from VE at all.
What I need is to get latest versions of all associated idw's relating to all the sub-assemblies and parts.
In VE, I can individually select each part/assembly, look at used in and see the idw's and get the latest versions.
But this is tedious and time consuming, especially with diffferent BOMs and plenty of components.
If VE would allow me to include all parents, including all idw's instead of only ipt's, this would solve the problem.
I need a simple and easy way to get all associated idw's related to all sub-parts/assy's. If there is a command line that I can use, then I could possibly use VB or exe file of some sort.
Message 4 of 9
Madhan_T
in reply to: kevin
I will check this for you and update you.
Does the excel file has information about the path of the files?
Madhan
Edited by: Madhan_T_autodesk on Nov 19, 2008 7:29 PM
Principal Engineer
Autodesk, Inc.
Message 5 of 9
kevin
in reply to: kevin
Thanks.
The exel spreadsheet can be produced with individual path locations. I have those locations.
Although the inventor parts and odw's are not in the same folders, I can get them shifted across into the same folder. Unless there is a command that automatically finds the associated idw.
Message 6 of 9
in reply to: kevin
style="FONT-SIZE: 10pt; LINE-HEIGHT: 115%; FONT-FAMILY: 'Arial','sans-serif'">Hi,
I
have just realized that there is a simple option that helps to get the parent
IDW files. I hope this helps.
Please select all the files in
under "Uses" tab and go to "Get latest version" in that dialog select "Settings"
and enable "Include Parents". This would bring all the IDW files associated with
the Part files. Please refer the attached image for reference.
If
you have further questions, please let me
know
Madhan
face=Calibri>
Thanks.
those locations. Although the inventor parts and odw's are not in the same
Message 7 of 9
kevin
in reply to: kevin
Thanks Madhan
Gave it a try - is far easier but will either get too many or too few of all the components I need.
For the moment - I reckon this will work - if you can find the command line prompt for get latest version, would really appreciate it for future reference.
Thanks again.
Message 8 of 9
Madhan_T
in reply to: kevin
You are welcome. Please send me the sample excel file to me (madhanagopal DOT t AT autodesk DOT com). I will check if I can help you with command line utility.
Madhan
Principal Engineer
Autodesk, Inc.
Message 9 of 9
in reply to: kevin
style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-SG">Another
Option..
style="FONT-SIZE: 12pt; FONT-FAMILY: 'Times New Roman','serif'; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-SG">
style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-SG">You
may specify the PART files separated by "OR" operator in "Advanced
Find" dialog and select all the files for "Get latest version" including
parents. Please refer the attached image.
style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-SG">Regards,
style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-SG">Madhan
size=2>
Madhan Gave it a try - is far easier but will either get too many or too few
of all the components I need. For the moment - I reckon this will work - if
appreciate it for future reference. Thanks again.
