Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Get Previous version in Vault Basic
2 REPLIES 2
CDemarest
420 Views, 2 Replies
What is the process to Get Previous Version with Vault Basic 2014?  If I select Get/CheckOut for a file with previous versions, the only version that I can check from the history is the latest version.
2 REPLIES 2
minkd
in reply to: CDemarest
You can either download (without checking it out) the version you want and then checkout the file without downloading it; or you checkout the file without downloading it, and then get the historical version without checking it out. I think the latter is probably less error prone. Either way you will end up with a checked-out file where the file in your workspace is the historical version. -Dave
Dave Mink
Fusion Lifecycle
Autodesk, Inc.
karthur1
To "Get Previous", select the file like you did in the first screen shot.  You will not be able to check the box like you show in the second screen shot b/c it is not the latest version. Only the latest version can be checked out from Vault Explorer. If you want to check-out a version other than the latest, you first get latest from Vault and select the version you want, then go to inventor and check it out from there.
Hope that helps,
Kirk
