Recently we had a metting with a potential customer. He asks whether its possible to force the user to enter comment at check-in of a file? (Can be a design file or an office document)
Cheers,
I'm open to be proven wrong, but as far as I know you can't do this using standard product features, Autodesk aren't big on giving admins the option to enforce rules like this even though in many cases it's something we really really want to be able to do. Initially my first thought (on Workgroups or Pro) was maybe we could create a Vault based file rule to redirect a file with no comment onto a lifecycle which the users have read and modify rights denied, which would in turn block the file from being created in Vault. But then I remember logging a ticket years ago to have that behaviour reversed, and it was wups. But even then, it would be a complicated and messy workaround.
If this is vitally important, if it was me I'd get in touch with an Developer Network partner and get a custom VB application created to satisfy this requirement. I've had several of these type of apps created to patch up things that I need Vault to do. A skilled programmer could probably knock up something like this in a day or two.
Hi Neil,
Thank you very much for your reply. I'll try to find a developer. 🙂
Cheers,
I'm not positive on this as I haven't personally tried it, but I'm almost sure that Data Standard can't apply enforcements like that, even in Pro. I asked the question a little while ago and Doug Redmond responded saying it can't go that far, but we might have been discussing a different property enforcement. Either way, I'm totally wanting to be proven wrong if someone can confirm it can do this and show an example as I have a current requirement for this kind of feature.
Is this still true, there is no way to enforce comments when checking in files into Vault Group 2019 or newer?
