Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Folder wont move due to file I can't find
3 REPLIES 3
powder1742
499 Views, 3 Replies
I'm trying to move a folder in vault to a new location.  I get the following message when I try to move it:
"Folder 'folder name' cannot be moved due to vault restrictions"
Details>>
Affected Object                        Restriction
1202-320-34-01-00_idw.dwf       File is checked out.
Now I understand you cannot move a folder when stuff is checked out.  The problem is I cant find the file listed above.  I've tried searching for file extensions, and even file name.  Does this have something to do with the double file extension?
Adrian
3 REPLIES 3
Senthil_Kumar
in reply to: powder1742
Try enabling the Show Hidden Files options via Tools Menu->Options-> Check "Show Hidden Files" Box and then try to if you can find the DWF file.
Hope that helps.
Senthil Kumar
Development Manager,
Be sure to check out the Vault Help!
powder1742
That did it!  Thanks for the help.  I figured it was a hidden file!
Thanks again!
Adrian
luttena
Adrian,
Something to think about would be how the hidden file got into a checked out state so that this doesn't occur in the future. The hidden visualization files are not usually checked out because the Vault should maintain this file. You will see that by checking out the CAD file it represents, the dwf is never checked out automatically. Perhaps it was specifically selected and checked out for some reason.
Adam
Adam Luttenbacher
Sr User Experience Designer
