I've been trying to use VP2014 to create a folder-based report template and i'm finding that none of the folder properties will show up in the report when run. I've created initial RDLCas a folder type with the specific folder properties i need, but again, nothing shows up when the report is ran against a folder within VP. My file and item-based reports work fine.
Any ideas? Does this actually work - folder-based reports? Is there anything out of the ordinary you must do to make this work?
Any Solutions on this, I have tried creating the reports in Visual Studio, still not able to get the Folder Name, surprisingly as the Autodesk Vault MSSql database has been migrated to 2012 but the reporting still uses the Visual Studio 2008 which does not support the latest version of MSSql. "Irony"
