No longer able to access files from vault..... Installed the 2014 software on workstation, then went to install on server, realized we need a server upgrade. Went to go use 2013 software again on workstation and can see folders but no files. Vault is there but not there.....
I deleted all autodesk software to try and start over still no luck
anohter user has no problems on his workstation.......
How do I get my 2013 to work again untill new server arrives and we can try to install 2014 again
Software is product design suite ultimate
Jim
log into vault with another user on my workstation, same problem, so something was changed on my workstation......
This also happened to me a few months back. See this thread for the answer:
Good luck!
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Install Vault 2013 SP1 from http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21017345&linkID=9261341. We have fixed the .Net issue with this.
