Vault General Discussion
Valued Mentor
tmccar
Message 1 of 8 (932 Views)
Files not showing in Vault
932 Views, 7 Replies
08-25-2011 03:59 AM
I am logged in to Vault 2011 Pro client, and the vault is empty. But in Autocad and Inventor, when I log in to the same vault, I see a dwg file and an ipart. Why is this?
    I trird refreshing the vault client, also logging out and in again.
Look at your image, you have a filter set for your view.  If you look at the icon to the right of the search box, you will see a filter icon.  Try clearing your filter settings.
CAD-One
Message 2 of 8 (919 Views)
Re: Files not showing in Vault
08-25-2011 07:25 AM in reply to: tmccar
I would think its got to do with folder permissions? But then not sure also, because you said you see it in vault-add-in thru CAD.
Lets see some else has any comments..
C1
Inventor Professional 2015
Vault Professional 2015
Employee
JamesMcMullen
Message 3 of 8 (907 Views)
08-25-2011 08:03 AM in reply to: CAD-One
When you select your folder on the right side to you see two panels on top of each other or just one?  Sometimes, I have seen where the tab area is overwrites the file location and you just need to scroll the bar down.
-Jim
CAD-One
Message 4 of 8 (905 Views)
08-25-2011 08:15 AM in reply to: JamesMcMullen
You mean adjust (pull up / down) the view pane slipper?
C1
Employee
JamesMcMullen
Message 5 of 8 (900 Views)
08-25-2011 08:36 AM in reply to: CAD-One
Correct, I found sometimes that gets stuck.
-Jim
Valued Mentor
tmccar
Message 6 of 8 (893 Views)
08-25-2011 09:19 AM in reply to: JamesMcMullen
No, the folder is definitely visible on the right
Board Manager
ihayesjr
Message 7 of 8 (884 Views)
08-25-2011 10:09 AM in reply to: tmccar
Irvin Hayes Jr
Product Manager
Valued Mentor
tmccar
Message 8 of 8 (864 Views)
08-26-2011 12:58 AM in reply to: ihayesjr
Yes, that's the one Irvin, thanks!
New button for Platinum & Gold Subscription customers
Gold & Platinum Subscription customers can alert Autodesk if they require assistance with their forum post
Manufacturing Community
