I am logged in to Vault 2011 Pro client, and the vault is empty. But in Autocad and Inventor, when I log in to the same vault, I see a dwg file and an ipart. Why is this?
I trird refreshing the vault client, also logging out and in again.
Solved by ihayesjr. Go to Solution.
I would think its got to do with folder permissions? But then not sure also, because you said you see it in vault-add-in thru CAD.
Lets see some else has any comments..
When you select your folder on the right side to you see two panels on top of each other or just one? Sometimes, I have seen where the tab area is overwrites the file location and you just need to scroll the bar down.
-Jim
You mean adjust (pull up / down) the view pane slipper?
Correct, I found sometimes that gets stuck.
-Jim
Look at your image, you have a filter set for your view. If you look at the icon to the right of the search box, you will see a filter icon. Try clearing your filter settings.
