Vault General Discussion
Active Contributor
0 Kudos
Post 1 of 4
filenamne.mdf is not a primary database file.
1150 Views, 3 Replies
11-02-2011 12:30 AM
Hi.
When i try to attach my library i get an error saying:
c:\Programfiles (x86)\Microsoft SQL Server\MSSQL\Data\AI2010_Nordform.mdf is not a primary database file.
The error.log file says:
2011-11-02 08:21:19.51 spid54      Starting up database 'Vault'.
2011-11-02 08:21:57.36 Logon       Error: 18456, Severity: 14, State: 8.
2011-11-02 08:21:57.36 Logon       Login failed for user 'sa'. [CLIENT: <local machine>]
2011-11-02 08:21:57.39 spid51      Starting up database 'AI2010_Inventor ISO'.
2011-11-02 08:21:57.48 spid51      Setting database option SINGLE_USER to ON for database AI2010_Inventor ISO.
2011-11-02 08:22:05.96 Logon       Error: 18456, Severity: 14, State: 8.
2011-11-02 08:22:05.96 Logon       Login failed for user 'sa'. [CLIENT: <local machine>]
2011-11-02 08:22:13.07 spid51      Configuration option 'show advanced options' changed from 0 to 1. Run the RECONFIGURE statement to install.
2011-11-02 08:22:13.07 spid51      Configuration option 'xp_cmdshell' changed from 0 to 1. Run the RECONFIGURE statement to install.
2011-11-02 08:22:13.08 spid51      Configuration option 'show advanced options' changed from 1 to 0. Run the RECONFIGURE statement to install.
2011-11-02 08:22:13.13 spid51      Configuration option 'show advanced options' changed from 0 to 1. Run the RECONFIGURE statement to install.
2011-11-02 08:22:13.13 spid51      Configuration option 'xp_cmdshell' changed from 1 to 0. Run the RECONFIGURE statement to install.
2011-11-02 08:22:13.15 spid51      Configuration option 'show advanced options' changed from 1 to 0. Run the RECONFIGURE statement to install.
2011-11-02 08:22:13.15 spid51      Configuration option 'show advanced options' changed from 0 to 1. Run the RECONFIGURE statement to install.
2011-11-02 08:22:13.15 spid51      Configuration option 'xp_cmdshell' changed from 0 to 1. Run the RECONFIGURE statement to install.
2011-11-02 08:22:13.16 spid51      Configuration option 'show advanced options' changed from 1 to 0. Run the RECONFIGURE statement to install.
2011-11-02 08:22:13.22 spid51      Configuration option 'show advanced options' changed from 0 to 1. Run the RECONFIGURE statement to install.
2011-11-02 08:22:13.22 spid51      Configuration option 'xp_cmdshell' changed from 1 to 0. Run the RECONFIGURE statement to install.
2011-11-02 08:22:13.22 spid51      Configuration option 'show advanced options' changed from 1 to 0. Run the RECONFIGURE statement to install.
2011-11-02 08:25:04.09 spid52      Starting up database 'Vault'.
Can the size of the Vault.mdf generate this problem. The database file is 3,983GB...
Active Contributor
0 Kudos
Post 2 of 4
Re: filenamne.mdf is not a primary database file.
11-02-2011 12:44 AM in reply to: cedergren
If I look at Propertys for AI2010_Nordform.mdf it says that it is a primary database file...
Product Support
20 Kudos
Post 3 of 4
11-02-2011 05:53 AM in reply to: cedergren
What were the circumstances leading up to attaching this library manually?
The error usually indicates that the file is most likely damaged.
-Hywell
Hywell Herrero
Data Management Support Specialist
Product Support
Autodesk, Inc.
Active Contributor
0 Kudos
Post 4 of 4
11-03-2011 03:26 AM in reply to: herrerh
Is there anyone who can help me to recover a corrrupt .mdf file? pls...
My backup is old.. :´(
Post to the Community
New Post
Announcements
New button for Platinum & Gold Subscription customers
Gold & Platinum Subscription customers can alert Autodesk if they require assistance with their forum post
Manufacturing Community
The Manufacturing Community provides additional access to tips, tutorials, blogs and networking with peers.
