Gang....run into this issue every once and awhile.
We have files that are phantoms and are put together and used when we have alot of duplicate assemblies. That way you can constrain once and array.
We want to lock these files down via the item, so we manually attach them to the appropriate item. Sometimes we use this same phantom assembly in other layouts so they potential could be manually linked to several items.
Problem is....we have no way of determine which items these phantom assemblies are linked to.
Is there a command we are missing which will allows us to see where these phantom assemblies are linked?
The "Go To Item" command only works for files which have been assigned.
Our biggest problem is taht we have a phantom which has been manually linked to an item, but we can't find what item it's linked to so that we can modify the file.
Any insight would be appreciated.
Thx,
Steve H.
Solved by smilinger. Go to Solution.
