This sounds like a problem we ran across a while back, where problems during
the indexing process actually create invalid database entries, resulting in
a bad property definition that you cannot fix in the dialog.
There have been other support cases regarding this problem; I would suggest
you work the support channel to try to get a resolution. If you run into
troubles there, please let me know.
Best,
Jeff
wrote in message news:5067365@discussion.autodesk.com...
In Vault 4 Explorer, when I try to go into the file property management to
turn off the indexing of unused properties, I get the error "The name cannot
contain any of the following characters: \/:*?"<>|"
None of the property names have any of those characters.
Some of the properties may contain those characters such as dates. The only
other property that has / in it is the description which may be something
like "1/4-20 X 1/2."
I cannot even open the property manager and just hit okay without making any
changes without getting the error. Is there a fix for this?
