I have a user who checked out a drawing and the associated Inventor assembly for editing. Now he is checking the whole deal back in. He is continually getting, on multiple items, the error message: "A file with this name already exists in the Vault". Of course it does.... he just checked it out yesterday. These are primarily Content Center parts. Any reason why Vault will not allow him to check them back in? They have not been modified in any way, other that their position in the assembly.
Vault pro 2015, Inventor 2015
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Solved by smithmat. Go to Solution.
One possible way this can happen is as follows:
So, in your case, the first question is:
Is there another file somewhere else that has the same name?
In either case, in the short term, to work around it--turn off "Enforce Unique File Names" temporarily.
Hope that helps,
- Matt
So simple. Thank you. The box did in fact get checked while I was playing around with some stuff yesterday, and I completely forgot about it. Thank you fine sir.
Chris Benner
