Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Field names remove spaces
3 REPLIES 3
148 Views, 3 Replies
I have a custom iProp called PART DWG. It shows in the field list as
PARTDWG. Is this a bug or as intended?
Dave Hoder
Product Design Engineer
idX Seattle
www.idxcorporation.com
Using Inventor v10sp3a / Productstream 4.5
3 REPLIES 3
This is intended because the SQL server can not have spaces in property
names.
If your are using vault 4 or later you can override this as a one time
operation. Go to Tool > Administration and select the file properties
button - in ther you can set a display name - to anything you want.
Brian Roepke
Product Manager, MSD
Data Management
Thanks Brian!
Brian Roepke (Autodesk, Inc.) writes:
Vault should do that automatically. When it changes the name of an
iProperty to make it compliant it should set the display name to the
original name.
Matthias
