I have installed a stand alone Vault Pro 2012 Server on Server 2008 R2 with 5 licenses (all correctly appended into the LIC file). IPV6 is not enabled. I even made a host file with server name and IPV4 address on the server and client.
I configured everything in LMTOOLS per direction. I only have ONE client trying to login - and I get the "Failed to acquire a license" error. The end user OS is Win 7 Pro 64 bit. The Vault sees the server and the Vault, but won't give out a license.
Any suggestions to remedy this would be greatly appreciated!!
Solved by OPXBIO. Go to Solution.
Dumb question, but did you check that the lisense server was started and running?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Yes - but we just found the solution. We found an old post regading the LICPATH. Removed the server name (huh???) and replaced it with 127.0.0.1. Makes absolutely no sense. I have spent 2 days trying to figure this thing out. So - to all of you that think this solution will never work - try it anyway!!!
I've just now tried this solution with success where everything else failed - thanks much!!
