I have installed a stand alone Vault Pro 2012 Server on Server 2008 R2 with 5 licenses (all correctly appended into the LIC file). IPV6 is not enabled. I even made a host file with server name and IPV4 address on the server and client.
I configured everything in LMTOOLS per direction. I only have ONE client trying to login - and I get the "Failed to acquire a license" error. The end user OS is Win 7 Pro 64 bit. The Vault sees the server and the Vault, but won't give out a license.
Any suggestions to remedy this would be greatly appreciated!!
Dumb question, but did you check that the lisense server was started and running?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Yes - but we just found the solution. We found an old post regading the LICPATH. Removed the server name (huh???) and replaced it with 127.0.0.1. Makes absolutely no sense. I have spent 2 days trying to figure this thing out. So - to all of you that think this solution will never work - try it anyway!!!
I've just now tried this solution with success where everything else failed - thanks much!!
