Vault General Discussion
aguitton116
Message 1 of 4 (237 Views)
Accepted Solution
Fail to install MS Office addin
237 Views, 3 Replies
02-20-2012 05:37 AM
Hi everyone,
I read a couple of topics about problems to install the addin but it's not exactly similar to my problem. In my case, I know how to install it and I see it on the list while running vault client installation (Pro 2012 x64 in my case).
When I check the box and want to come back, the setup wizard tells me that the addin is already installed and that I have to remove it before installing it again. The problem is that i can't see the addin in windows configuration panel, nor in word or excel preferences/addin/COM addins.
All my softwares are in french, including the OS of course (which is windows 7 pro SP1 x64). How can I remove the office addin manually in order to reinstall it properly ?
Hi Aguitton116,
yes, the office addin can't be installed if another version office add-in is installed. And Office addin is a feature of vault client installation, you only can remove or add it via vault client installation.
 So could you check if you have another vault flavor or previous version vault client installed in your machine? if yes,  please continue to check whether they have installed an office add-in already.  if yes, you can remove the old office add-in via other version vault client installation, and then the new office addin should can be installed via the 2012 vault client installation (pro 2012 x64).
Hope it is helpful.
Regards
Lynn
Employee
Lynn2009
Message 2 of 4 (217 Views)
Re: Fail to install MS Office addin
02-22-2012 06:23 PM in reply to: aguitton116
Hi Aguitton116,
Hope it is helpful.
Regards
Lynn
aguitton116
Message 3 of 4 (199 Views)
02-24-2012 12:01 AM in reply to: Lynn2009
Thanks it works now !
II had my vault 2011 client still installed. I removed it and I then installed the MS Office addin for Vault 2012.
Arnaud
Employee
Lynn2009
Message 4 of 4 (196 Views)
02-24-2012 12:08 AM in reply to: aguitton116
Glad to hear that !
Announcements
New button for Platinum & Gold Subscription customers
Gold & Platinum Subscription customers can alert Autodesk if they require assistance with their forum post
Manufacturing Community
The Manufacturing Community provides additional access to tips, tutorials, blogs and networking with peers.
Need installation help?
