I have been trying to check-in a presentation into Vault and I keep getting the following error.
Has anyone seen this error before? Any idea wha needs to be done?
The assembly checks in fine. This is what I see in the Model Browser (tree) but I have no clue what the 3rd Party (plastic_Smooth_bump.png) is
Any help will be appreciated.
Thanks a lot.
Hi There,
This is an Inventor issue. The initial message indicates that the reference to that material is not detailed in your project file support paths (workspace, library etc). I would suggest moving that to one of these locations.
Hope this helps.
Note that the bitmap is a material being referenced - you can also try to just remove it...
There should be an option to delete the link - try:
Tools > Options > Links command
