Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Error running BCS command in Autodesk.Vault.BCSConnect: 301
4 REPLIES 4
mbodnar
818 Views, 4 Replies
Hi
Does anyone know how to resolve this error? Comes up when trying to access ITEMS/FILE list created in sharepoint?
Configured all steps until Customizing a Vault List in the "AUTODESK VAULT FOR SHAREPOINT 2010" guide
Max Bodnar
4 REPLIES 4
gaol
in reply to: mbodnar
Hi Max,
One similar case: http://forums.autodesk.com/t5/Autodesk-Vault/Vault-Pro-2013-Sharepoint-2010-Integration/m-p/3660760
You can try if yours are the same root cause with that one.
A log will help us know your problem.
Lily
mbodnar
Hi Gaol
I have tried the following
1. Ran retract all.bat and deploy all.bat
2. Imported the BCS model
3. Applied permissions to all 3 external models as per the documentation
Error 301 still persists. I had a string of other error but I cannot resolve the 301 error
The log you mentioned, where could I locate this?
The history of this site is I could access the Vault information before hand, not thru the site but thru central administration site and since I have had to detach the Vault and re-attach it.
Since then I have encountered the error
Max Bodnar
Redmond.D
Error 301 means "invalid username or password".  Go to your Vault settings page and enter in the the Vault username/password again.  Also, make sure to check the box that indicates that you are updating the password.
Doug Redmond
Software Engineer
mbodnar
Thanks Doug
Regards
Max Bodnar
