Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Error "Illegal characters in path" when copy design
4 REPLIES 4
spascual
1812 Views, 4 Replies
Hi Sirs,
I have found this issue when copy design. Parents, sons and neighbours files run well as alone copy.
Attached you can find an image and log lines in server...
06/05/2011 11:45:39 *******************************************************************
Error: Soap Exception ( mesg-id = 634402791399426250 )
Exception: GetFileFailed [1013]
Stacktrace:
Server stack trace:
   en Connectivity.Document.BusinessLogic.FileBL.GetFilesByMasterId(Int64 masterId)
   en Connectivity.Document.Services.FileService.GetFilesByMasterId(Int64 masterId)
   en System.Runtime.Remoting.Messaging.Message.Dispatch(Object target, Boolean fExecuteInContext)
   en System.Runtime.Remoting.Messaging.StackBuilderSink.SyncProcessMessage(IMessage msg, Int32 methodPtr, Boolean fExecuteInContext)
Exception rethrown at [0]:
   en System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg)
   en System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type)
   en Connectivity.Web.Services.DocumentService.GetFilesByMasterId(Int64 fileMasterId)
Stacktrace:
Server stack trace:
4 REPLIES 4
r.smith1
in reply to: spascual
Please see our support blog regarding the log entry you provided us Here.
Can you please be more specific with the problem you see with Copy Design.  Unfortunately I cannot view your tiff image.
Ron Smith
New Product Introduction Manager
spascual
in reply to: r.smith1
Hi Mr. Smith,
Attached you can find the error dialog box when try to do a copy design.
In Inventor environtment, runs well.
I can rename the file.
I can move the file.
Its parents and its sons can be copied.
Regards
spascual
It seems like in the log file is writing nothing
shawn.payne
Is there a solution for this? I am having the same problem.
