Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Error populating Files
4 REPLIES 4
139 Views, 4 Replies
Hi.
When browsing for files in VaultExplorer, I recive timeout when "wait for
grid to populate". The database is quite large
and waiting is iritating. What can be done for at least getting the files to
populate?
Thankful for all help
/Henrik Andersson
4 REPLIES 4
You probably need to increase the defaultSqltimeout value in the web.config
file on the server.
- jeff
"Henrik Andersson" wrote in message
news:5117727@discussion.autodesk.com...
Hi.
populate?
/Henrik Andersson
Allright, this is the current configuration:
Any suggestion in what value that should work better?
Do I have to change the value for as
well?
/ Henrik Andersson
"Jeff Pek (Autodesk)" wrote in message
news:5117908@discussion.autodesk.com...
file on the server.
- jeff
Hi.
populate?
/Henrik Andersson
As a start, I'd try doubling the defaultSqlTimeoutSecs value (to 200), and
see how things go. It won't hurt to change the "long" timeout value, but
that is used much less often, so likely won't have much impact.
- Jeff
news:5119131@discussion.autodesk.com...
well?
/ Henrik Andersson
file on the server.
- jeff
Hi.
populate?
/Henrik Andersson
Okey, I'll try that.
Thanks for your help regarding this problem.
- Henrik Andersson
news:5119270@discussion.autodesk.com...
- Jeff
well?
/ Henrik Andersson
file on the server.
- jeff
Hi.
populate?
/Henrik Andersson
