Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Error occurred trying to retrieve a file
1 REPLY 1
Raider_71
291 Views, 1 Reply
Hi guys,
Any idea why we would be getting this message? It happens especially after a copy design was done and then trying to open the files from Vault. If you refresh and wait and try again later it works fine with no error. Its always the ipj file thats doing it. Also worth mentioning is that this has started happening after upgrading to Vault 2014.
1 REPLY 1
the issue you have is described in this blog article:
http://crackingthevault.typepad.com/crackingthevault/2014/02/error-on-project-file-when-opening-inve...
Can you try the instructions of the workaround?
The issue shouldn´t appear anymore after applying the setting in the Connectivity.VaultPro.exe.config
Kevin Jaufmann-Ludwig
Technical Support Specialist
Link Name | Link Name | Link Name | Link Name
