Vault General Discussion
Active Member
0 Kudos
Post 1 of 9
Error message when I open VAULT
185 Views, 8 Replies
02-07-2013 07:42 AM
My problem is : When I want to open VAULT, the next message appear : erreur_vault.jpg
Is somebody know this problem ?
Thanks for your help.
Regards.
This looks like .NET has either been corrupted or uninstalled.
Try doing a repair-install on .NET 4.0 and see if that helps.
-Dave
846 Kudos
Post 2 of 9
Re: Error message when I open VAULT
02-07-2013 07:50 AM in reply to: jchaule
I don't read french, but I can tell by looking at this that it is some sort of registry error.  It appears to be an installation issue of some sort.  Do you have an IT person at your company that can look at this?
ChrisB / Twitter
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
http://cadtipstricks.wordpress.com//
Active Member
0 Kudos
Post 3 of 9
02-07-2013 07:55 AM in reply to: cbenner
Thanks to respond quickly.
I'm an IT person but I'm not a VAULT specialist.
You mean that it is a log of this with more details ?
846 Kudos
Post 4 of 9
02-07-2013 08:15 AM in reply to: jchaule
I don't know what the problem is.  I think we need more information about what you installed and how.  Would it be possible to translate the error screen?
ChrisB / Twitter
Active Member
0 Kudos
Post 5 of 9
02-07-2013 08:30 AM in reply to: cbenner
I have found the same error but in English for you.
What is strange, it's that this message is appeared after one month of the installation...
Also, AUTOCAD LT is installed on the computer... Perhaps a compatibility problem between them.
Active Member
0 Kudos
Post 6 of 9
02-07-2013 08:42 AM in reply to: jchaule
I have to leave.
I responded to you only tomorrow morning, if you try something of course.
Thanks a lot to search for me a solution.
It's nice.
Best regards.
Employee
48 Kudos
Post 7 of 9
02-07-2013 09:38 AM in reply to: jchaule
-Dave
Dave Mink
Data Management
Active Member
0 Kudos
Post 8 of 9
02-07-2013 11:31 PM in reply to: minkd
Thanks. I try it when it's possible and I tell you if it's good or not
Active Member
0 Kudos
Post 9 of 9
02-08-2013 01:38 AM in reply to: minkd
Dave,
You had reason. It was .Net Framework which was broken. But not the 4.0, it was the 3.5.
I'm forced to activate it  in  "Turn Windows fetaures on or off" and to check "Microsoft .Net Framework 3.5.1".
Thank you very much to have put me in the good way !
Thank you also to ChrisB to take a part of time for my problem !!
Have a good day !
Regards
New button for Platinum & Gold Subscription customers
Gold & Platinum Subscription customers can alert Autodesk if they require assistance with their forum post
Manufacturing Community
