Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Error message when I open VAULT
8 REPLIES 8
Message 1 of 9
506 Views, 8 Replies
My problem is : When I want to open VAULT, the next message appear : erreur_vault.jpg
Is somebody know this problem ?
Thanks for your help.
Regards.
8 REPLIES 8
Message 2 of 9
cbenner
I don't read french, but I can tell by looking at this that it is some sort of registry error.  It appears to be an installation issue of some sort.  Do you have an IT person at your company that can look at this?
Message 3 of 9
in reply to: cbenner
Thanks to respond quickly.
I'm an IT person but I'm not a VAULT specialist.
You mean that it is a log of this with more details ?
Message 4 of 9
cbenner
Message 5 of 9
I have found the same error but in English for you.
What is strange, it's that this message is appeared after one month of the installation...
Also, AUTOCAD LT is installed on the computer... Perhaps a compatibility problem between them.
Message 6 of 9
I have to leave.
I responded to you only tomorrow morning, if you try something of course.
Thanks a lot to search for me a solution.
It's nice.
Best regards.
Message 7 of 9
minkd
This looks like .NET has either been corrupted or uninstalled.
Try doing a repair-install on .NET 4.0 and see if that helps.
-Dave
Dave Mink
Fusion Lifecycle
Autodesk, Inc.
Message 8 of 9
in reply to: minkd
Thanks. I try it when it's possible and I tell you if it's good or not
Message 9 of 9
in reply to: minkd
Dave,
You had reason. It was .Net Framework which was broken. But not the 4.0, it was the 3.5.
I'm forced to activate it  in  "Turn Windows fetaures on or off" and to check "Microsoft .Net Framework 3.5.1".
Thank you very much to have put me in the good way !
Thank you also to ChrisB to take a part of time for my problem !!
Have a good day !
Regards
