My problem is : When I want to open VAULT, the next message appear :
Is somebody know this problem ?
Thanks for your help.
Regards.
Solved by minkd. Go to Solution.
I don't read french, but I can tell by looking at this that it is some sort of registry error. It appears to be an installation issue of some sort. Do you have an IT person at your company that can look at this?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Thanks to respond quickly.
I'm an IT person but I'm not a VAULT specialist.
You mean that it is a log of this with more details ?
I don't know what the problem is. I think we need more information about what you installed and how. Would it be possible to translate the error screen?
Chris Benner
I have found the same error but in English for you.
What is strange, it's that this message is appeared after one month of the installation...
Also, AUTOCAD LT is installed on the computer... Perhaps a compatibility problem between them.
I have to leave.
I responded to you only tomorrow morning, if you try something of course.
Thanks a lot to search for me a solution.
It's nice.
Best regards.
This looks like .NET has either been corrupted or uninstalled.
Try doing a repair-install on .NET 4.0 and see if that helps.
-Dave
Dave,
You had reason. It was .Net Framework which was broken. But not the 4.0, it was the 3.5.
I'm forced to activate it in "Turn Windows fetaures on or off" and to check "Microsoft .Net Framework 3.5.1".
Thank you very much to have put me in the good way !
Thank you also to ChrisB to take a part of time for my problem !!
Have a good day !
Regards
