Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Error Message - Vault 2013
52 REPLIES 52
Message 1 of 53
2016 Views, 52 Replies
My group is starting to see the the message below. How can we fix this? This pops up when we are trying to check in files. IT doesn't happen all the time, but often enough that it's a problem.
52 REPLIES 52
Message 2 of 53
olearya
HI There,
What version of Vault is it that you are using?  You can check the following thread:
http://forums.autodesk.com/t5/Autodesk-Vault/Vault-2010-Exception-has-been-through-by-the-Target-of-...
Also look at whether or not anti-virus software on server or client could be an issue and perhaps look for some consistencies in the error such as user, file type or size, time of day, things of that nature.
Hope this helps.
Allan
Product Manager
Autodesk, Inc.
Message 3 of 53
in reply to: olearya
We are running Vault Basic 2013. We have looked into the Anti-Virus on the client side, and also the file sizes and time of day. The files sizes vari and the time of day varies.
Message 4 of 53
olearya
Sorry I just looked at the subject title - Vault 2013..... 🙂
Are there any entries in the server vlogs corresponding to the error?
Allan
Product Manager
Autodesk, Inc.
Message 5 of 53
Gettign another error message now when trying to do "Copy Design".  This one is new today and has happened both times doing a copy design.
Message 6 of 53
The vlog is showing the following:
Error: Soap Exception
Exception: BadAuthenticationToken [300]
Any help?
Message 7 of 53
JamesMcMullen
The 2 pictures show the same directory.  Do you have this problem with other directories on your system?  An error 300 usually means the hand shake between the client and server was disrupted somehow.
-Jim
James McMullen
Principal SQA Eng.
Message 8 of 53
in reply to: JamesMcMullen
It happens with different directories that was just luck.
So you think it's a software issue or a network issue?
Message 9 of 53
JamesMcMullen
I was hoping that we could narrow it down to the directory.  But as you mentioned, that is not the case.  In the SDK help, it mentions:  This can happen when the web services are restarted.  Are you moving large amounts of data?  If so, what type of files are they?  Honestly, I cannot say whether it is software or network related.
-Jim
James McMullen
Principal SQA Eng.
Message 10 of 53
They are by no means large files. You can see in the one pic I posted that its just over 900kb, that's pretty typical. What seems to happen is that some of the files transfer over and the other half are cut off. We can then go back and click on check-in again and they will then go in to the vault.
Message 11 of 53
JamesMcMullen
That is definitely odd.  Are these Inventor files or ACAD files?  You are correct 6 files at ~900kb should not be a problem.
-Jim
James McMullen
Principal SQA Eng.
Message 12 of 53
DanSingleton
We're experiencing the same problem.
Workstations:
Inventor 2013 (64 bit), Build 138, Release 2013 RTM
Vault Basic Client, Build 17.0.61.0
Server:
Windows Server 2003 R2 SP2 (64 bit)
Vault Basic Server 2013, Build 17.0.61.0
When I go the the server I have to click through a bunch of IIS Worker Process errors everytime this happens. They all say faulting application w3wp.exe, faulting module kernel32.dll
Searching the web and this site it looks like this has been around for a number of versions back to 2010... I haven't been able to find a permanent fix.
Message 13 of 53
Is it possible to get the error information that IIS is throwing?  I did a quick Google search as well and you are correct it looks like it has been around for a while though this is the first I think I heard of it.  There was another newsgroup thread that had a weird work around that worked for them:  http://forums.autodesk.com/t5/Autodesk-Vault/Vault-2012-and-w3wp-exe-and-not-being-able-to-check-ite...
I would like to get the IIS error though so that we can look into this more and get this resolved.
-Jim
James McMullen
Principal SQA Eng.
Message 14 of 53
They are all Inventor files, no ACAD.
Message 15 of 53
JamesMcMullen
Timchr,
Are you getting IIS errors as well?  If so, is it possible to get a snippet of the error?
Jim
James McMullen
Principal SQA Eng.
Message 16 of 53
The only error messages we have gotten is what I have posted. What are IIS errors, not familiar with that.
Message 17 of 53
JamesMcMullen
I am unsure if you have access to your server or not.  But if you do, you can go to "C:\inetpu\logs\LogFiles\W3SVC1" directory and get the logs that IIS writes out.  I would just look at the log for the day you see the error and look inside the file around the time you saw the error.  That might give us enough information to reproduce the issue here and work on getting a fix.
-Jim
James McMullen
Principal SQA Eng.
Message 18 of 53
-Jim
Sorry, I'd gone home for the day before your replies showed up.
Yup, I came across that thread as well. The weird workaround (checking ouit another file then checking it back in) isn't required... I simply click no when asked to continue to check in files and then restart the check-in for my files. 99% of the time it works the second time without any issues.
@Anonymous IIS server logs were located at C:\WINDOWS\system32\LogFiles\W3SVC1  I've attached the entire IIS file from yesterday. I can't see where it's specifically showing an error, unless it's the lines where it says "disco 80" I'm assuming that means disconnected @ port 80.
I've also attached a screenshot of a W3SVC error that shows up in the Server's Event Viewer under System events pretty much the same time these check-in errors do.
I'd almost guarantee timchr is getting the same IIS worker errors on their Vault server.
Message 19 of 53
in reply to: DanSingleton
@Dan... Those logs look the same as mine. I have attached the 3 latest error logs. I to select "no" and then run it a second time and so far no issues on the second attempt.
Message 20 of 53
DanSingleton
Guess this problem will still be around in 2014 as well. 😞
