Vault General Discussion
Dan.M
Message 1 of 5 (155 Views)
Error during check in
155 Views, 4 Replies
10-11-2009 07:10 AM
Hello All ,
During check in I got the following error . pic attached .
Anyone has a solution ?
Active Contributor
jorgen_bjornes
Message 2 of 5 (155 Views)
Re: Error during check in
10-11-2009 08:33 AM in reply to: Dan.M
I've had similar problems. The problem was primarily with checking in imported geometry.
Installing the TS1093427 hotfix fixed the issue.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=12268454&linkID=9242499
Make sure you do a proper backup and follow the instructions carefully.
Dan.M
Message 3 of 5 (155 Views)
10-11-2009 11:24 AM in reply to: Dan.M
What do you mean when you say " imported geometry " ? DWG files are imported geometry ?
Dan
Active Contributor
jorgen_bjornes
Message 4 of 5 (155 Views)
10-11-2009 12:11 PM in reply to: Dan.M
With imported geometry I mean that I had problems with SOME components that were imported from Step, sat etc.
3D DWG geometry is also non-inventor geometry, but I cannot say if dwg-geometry might cause this. I have mainly worked with imported STEP, not dwg.
Dan.M
Message 5 of 5 (155 Views)
10-13-2009 02:21 PM in reply to: Dan.M
I thinks that this error is coming from database itself. I tryed some maintenance scipts but nothing helped . The thing is that I can work normally for a few hours and suddenly everything is working very vey slowly and i get the error . Also when I am pointing on a folder inside the PS it takes 10 minutes maybe more to populate . I am thinking to do a reinstall of the entyre system .
Dan
New button for Platinum & Gold Subscription customers
Gold & Platinum Subscription customers can alert Autodesk if they require assistance with their forum post
Manufacturing Community
