Previous versions of vault have been on this windows 7 m/c.
Any pointers to get past this error?
no change after disconnectiong the network lead during the install - log below.
2014/9/16:08:41:11 andrewc ANDREWC-PC === Setup started on ANDREWC-PC by andrewc ===
2014/9/16:08:41:11 andrewc ANDREWC-PC Path_Length: 153
2014/9/16:08:41:11 andrewc ANDREWC-PC Current Directory C:\Users\ANDREW~1.QUA\AppData\Local\Temp\_AI40F5.tmp
2014/9/16:08:41:11 andrewc ANDREWC-PC Launch
2014/9/16:08:41:19 andrewc ANDREWC-PC PageOpen InstallDotNetDialog
2014/9/16:08:41:19 andrewc ANDREWC-PC PageOpen LaunchDialog
2014/9/16:08:41:22 andrewc ANDREWC-PC PageOpen LicenseDialog
2014/9/16:08:41:26 andrewc ANDREWC-PC PageOpen ProductInfoDialog
2014/9/16:08:42:30 andrewc ANDREWC-PC PageOpen ProductSelectionDialog2
2014/9/16:08:43:16 andrewc ANDREWC-PC PageOpen FullProgressDialog
2014/9/16:08:43:16 andrewc ANDREWC-PC Installing ADMS System Check: "I:\Apps\Autodesk\2015\Vault\Pro_S\x86\en-us\edmprechecks\edmwrapper_win32.exe" /qw /prechecks /c "COMMAND_GROUP=Precheck SQLPASSWORD="AutodeskVault@26200" DATADIR="C:\Program Files\Microsoft SQL Server" IISPORTNUMBER="80" IISWEBSITENAME="Default Web Site" ISUPGRADE="FALSE" UILANGFOLDER="C:\Users\ANDREW~1.QUA\AppData\Local\Temp\_AI40F5.tmp\en-us""
2014/9/16:08:44:35 andrewc ANDREWC-PC Install ADMS System Check Succeeded
2014/9/16:08:44:35 andrewc ANDREWC-PC Installing Microsoft Visual C++ 2012 Redistributable (x86): "I:\Apps\Autodesk\2015\Vault\Pro_S\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/9/16:08:45:32 andrewc ANDREWC-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/9/16:08:45:32 andrewc ANDREWC-PC Installing Microsoft Visual C++ 2012 Redistributable (x64): "I:\Apps\Autodesk\2015\Vault\Pro_S\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/9/16:08:46:32 andrewc ANDREWC-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/9/16:08:46:32 andrewc ANDREWC-PC Installing Microsoft SQL Server 2008 Express SP3 (AUTODESKVAULT): "I:\Apps\Autodesk\2015\Vault\Pro_S\3rdParty\sql2008Express\x64\setup.exe" /q /ACTION=Install /FEATURES=SQL /INSTANCENAME=AutodeskVault /SQLSVCACCOUNT="NT AUTHORITY\Network Service" /SECURITYMODE=SQL /SQLSYSADMINACCOUNTS="NT AUTHORITY\Network Service" /AGTSVCACCOUNT="NT AUTHORITY\Network Service" /ERRORREPORTING=0 /HIDECONSOLE /INSTANCEDIR="C:\Program Files\Microsoft SQL Server\\" /INSTALLSQLDATADIR="C:\Program Files\Microsoft SQL Server\\" /SAPWD="AutodeskVault@26200"
2014/9/16:08:48:57 andrewc ANDREWC-PC Install Microsoft SQL Server 2008 Express SP3 (AUTODESKVAULT) Succeeded
2014/9/16:08:48:58 andrewc ANDREWC-PC Installing Autodesk® Vault Professional 2015 (Server): TRANSFORMS="I:\Apps\Autodesk\2015\Vault\Pro_S\x64\en-us\VP_Server\Pro_Server.mst;C:\Users\ANDREW~1.QUA\AppData\Local\Temp\_AI40F5.tmp\x64\VP_Server\Pro_Server-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="I:\Apps\Autodesk\2015\Vault\Pro_S\" INSTALLDIR="F:\Autodesk\ADMS Professional 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/9/16:09:46:04 andrewc ANDREWC-PC Install Autodesk® Vault Professional 2015 (Server) Failed Installation aborted, Result=1603
2014/9/16:09:46:04 andrewc ANDREWC-PC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2014/9/16:09:46:04 andrewc ANDREWC-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
Regards
Andrew
Hi Andrew,
It seems like a permission issue while trying to start the SQL service. Can you go into the Windows Event Viewer and check if there are any Application errors returning there?
You can also try to start the SQL service manually using Windows Services. If the same error still returns, use the Local System Account to log on instead of Network Service and attempt to restart the SQL service again.
Samuel
Thanks Samuel
I ended up deleting all sql references & reinstalling.
Andrew
