Hi, I migrate the database from vault2012 SP1 on a windows server 2003 machine to the same version, vault2012 SP1 on a Windows 7 64bit machine.
Some drawings reports this problem:
17/09/2012 17:26:21 Could not validate or replicate resource 'Forno3012.iam.dwf' version 1. Located in the filestore at E:\VaultStore\filestore\Infragas\000\000\000\000\000\083\83490\83490_83491_1.dwf. 17/09/2012 17:26:21 ******************************************************************* Error: Soap Exception ( mesg-id = 634834995810920879 ) Exception: OrphanedMetaData [213] Stacktrace: Server stack trace: in Connectivity.Core.Operations.Replicator.a(Enum A_0, Resource A_1, List`1 A_2) in Connectivity.Core.Operations.Replicator.ReplicateResource(Resource res) in Connectivity.Core.Services.KnowledgeVaultService.GetNonlocalResource(Resource res) in System.Runtime.Remoting.Messaging.Message.Dispatch(Object target, Boolean fExecuteInContext) in System.Runtime.Remoting.Messaging.StackBuilderSink.SyncProcessMessage(IMessage msg, Int32 methodPtr, Boolean fExecuteInContext) Exception rethrown at [0]: in System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg) in System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type) in Connectivity.Core.Services.KnowledgeVaultService.GetNonlocalResource(Resource res) in Connectivity.Document.BusinessLogic.FileBL.DownloadFile(Int64 fileIterationId, Boolean allowSync, String& filename, Boolean skipFileSizeCheck) in Connectivity.Document.Services.FileService.DownloadFile(Int64 fileIterationId, Boolean allowSync, String& filename, Boolean skipFileSizeCheck) in System.Runtime.Remoting.Messaging.Message.Dispatch(Object target, Boolean fExecuteInContext) in System.Runtime.Remoting.Messaging.StackBuilderSink.SyncProcessMessage(IMessage msg, Int32 methodPtr, Boolean fExecuteInContext) Exception rethrown at [1]: in System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg) in System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type) in Connectivity.Document.Services.FileService.DownloadFile(Int64 fileIterationId, Boolean allowSync, String& filename, Boolean skipFileSizeCheck) in Connectivity.Web.Services.DocumentService.DownloadFile(Int64 fileId, Boolean allowSync, Byte[]& fileContents)
Can you please help me solving this problem? I'm getting crazy!
VAULT SERVER 16.1.58.0
BUILD 16.1.58.0
UPDATE 1
I also installed some hotfix on the website, without any result.
i probably have the same problem.
26.04.2013 21:28:01 Could not validate or replicate resource 'XXXX1830.idw.dwf' version 2. Located in the filestore at D:\Tresor\XXXXXXX\000\000\000\000\000\234\234694\234694_234795_2.dwf.
Inside the vault, I found the file and deleted hard. The next day I get the same message.
Best Regards
Holger
