Vault General Discussion
Employee
KooCheeKit
Message 21 of 60 (764 Views)
Re: Error 1455 Follow up
11-08-2012 07:19 PM in reply to: scottmoyse
Please log this issue with product support. Have to look into the database to determine the cause of the issue.
If you could share your backup at the state where the issue can be repro, i will take a look into the issue. After the backup, remove the filestores from the backup, this will reduce the size of the backup.
Chee-Kit
Distinguished Contributor
SveinE
Message 22 of 60 (755 Views)
11-09-2012 01:54 AM in reply to: KooCheeKit
Hi
We also have the same problem
It is logged as Case 07623711
Please prioritize this as there are several customer reporting it and there are no workaround as I can see
The Item can not be updated, export to ERP stop..., etc
br
Svein
Valued Mentor
MaximUdod
Message 23 of 60 (748 Views)
11-09-2012 02:54 AM in reply to: SveinE
Just in case, you can try this workflow:
1. Remove all file links
2. Assign primary file back
3. Update Item
scottmoyse
Message 24 of 60 (745 Views)
11-09-2012 02:55 AM in reply to: MaximUdod
cheers for the suggestion, but often you can't create the item in the first place let alone update it...
Cheers
Scott Moyse
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Cheers!
Valued Mentor
MaximUdod
Message 25 of 60 (742 Views)
11-09-2012 02:59 AM in reply to: scottmoyse
Not sure I understand you clearly.
Are you sure everything that need to be checked-in prior to Item creation is checked-in?
scottmoyse
Message 26 of 60 (735 Views)
11-09-2012 03:07 AM in reply to: MaximUdod
yes everything is checked in. This is a known issue. one which has been around for months now but unfortunately still hasn't been fixed. It only appears to occur on installations where Vault 2013 ADMS is installed & being used with Inventor 2012 & Vault Client/AddIn 2012
Cheers
Scott Moyse
scottmoyse
Message 27 of 60 (741 Views)
11-09-2012 03:12 AM in reply to: KooCheeKit
Chee-Kit
thankyou I have logged it and supplied a link to download our database. The support case number is:
07798022
Cheers
Scott Moyse
SveinE
Message 28 of 60 (730 Views)
11-09-2012 03:12 AM in reply to: scottmoyse
ADMS 2013, Inventor 2013 sp1.1 and Vault Pro 2013 client on this site
br
Svein
scottmoyse
Message 29 of 60 (728 Views)
11-09-2012 03:14 AM in reply to: SveinE
br
Svein
well that makes it even worse. I had hoped that upgrading to Inventor 2013 in a couple of weeks would alleviate the problem.
Did you submit a backup of your database as well Svein?
Cheers
Scott Moyse
SveinE
Message 30 of 60 (722 Views)
11-09-2012 03:15 AM in reply to: scottmoyse
Sorry:-(
br
Svein
New button for Platinum & Gold Subscription customers
Gold & Platinum Subscription customers can alert Autodesk if they require assistance with their forum post
Manufacturing Community
