Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Error 1024 in Vault 2011 on Copy Design
13 REPLIES 13
Message 1 of 14
AlexErman
2161 Views, 13 Replies
Hello all,
I am getting an Error 1024 when I want to make a Copy Design and using multi selection. It happens, when I want to de-select content center files. It happens when I want to create a new folder using Copy Design option and content center files are included. If I create new folder, show it in 'Copy Design To:' it works, but I think the option to create the new foldet with Copy Design worked in Vault 2010. Is this a bug?
Movie of error occuring : http://screencast.com/t/xucet8g1Eb76
Best regards,
Alex
13 REPLIES 13
Message 2 of 14
mollons
in reply to: AlexErman
Yes, this seems to be a problem with Copy Design and library files.
We have started looking into it.
If you wish to reuse the library files, I believe your video illustrates the way to workaround the problem.
If you wish to copy design the library files unfortunately there may not be a workaround at this moment.
We will update this thread as we know more about the issue.
Scott Mollon
Quality Assurance
Autodesk, Inc.
Be sure to check out the Vault Help Wiki!
Message 3 of 14
AlexErman
in reply to: mollons
I acctualy don't want to copy library files, but with multi select I can't deselect them. The error doesn't happen when I create the destination folder first and then run copy design.
Movie: http://screencast.com/t/wMbnJhb9
Best regards,
Alex
Message 4 of 14
Whats the update.  It is Feb 3 And I got this same stupid BUG.
Message 5 of 14
r.smith1
Possible workaround for now is to create the copy design in place.
  • Do not change the "TO:" location at the top of the dialog box.
  • Change the library files from the copy selection back to reuse.
  • Rename the files or create a prefix that is easily searched (shold you wish) and apply to the files that are being copied.
  • Run the command.
  • Move the files to the desired location.
Ron Smith
Autodesk Product Support
Ron Smith
New Product Introduction Manager
Autodesk, Inc.
Message 6 of 14
jasonh70
in reply to: r.smith1
Ron pointed me to this thread when I asked him about the same problem.
I was able to use his workflow he listed, but after I added the prefix to my filename, I then changed the "TO" section and was able to run it sucessfully.
Inventor Professional 2014 Build 222
Dell Precision T3500, Intel Xeon W3550 3.07 GHz, 12GB RAM, Win7 SP1
Message 7 of 14
AlexErman
in reply to: jasonh70
As I posted before, everything works fine, if I create the destination folder first and I then select it with selection browser on Copy Design To:
Best regards,
Alex
Message 8 of 14
yuhui.zhang
Please try this fresh hotfix ts16172215.zip from http://usa.autodesk.com/adsk/servlet/ps/dl/item?id=16428729&siteID=123112&linkID=9261341.
Fay Zhang
Software QA Engineer
Data Management
Autodesk, Inc.
Message 9 of 14
AlexErman
in reply to: yuhui.zhang
Hotfix fixed the error for me.
Thanks and best regards,
Alex
Message 10 of 14
I am having the same issue with vault 2011. I tried the patch an got an error(please see attached screen shot) Am I missing a patch or another hot fix?
Message 11 of 14
you must install Vault 2011 Update 2 before this hotfix.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15670259&linkID=9261341
Alex
Message 12 of 14
Update 2 is required for this hot fix to be applied.
Ron Smith
Autodesk, Inc.
Message 13 of 14
After installing update 2 the patch was able to install. It is now running pretty slow but no errors. Does the update need to be on the server side as well? Could this be the reason for vault slowing down?
Message 14 of 14
correct, please install update 2 on all clients and servers at the same time.  please refer to readme for detail instruction of server upgrade.
Fay Zhang
Data Management
Autodesk, Inc.
