We have been getting the error 1013 when a serching for checked out parts. I found a procedure for how to fix: It requires deleting folders for the Vault file store/index. Where are these folders located? We are using Windows 7 - I know this changes the file path, but I cant find anything remotely looking like the lucene folder indexes.
The path suggested:
C:\program data\Autodesk\Vaultserver\filestore
I am assuming this is on the local user machine - this wouldn't be on the server would it?
Thanks.
Solved by Winks87. Go to Solution.
This would be on the Vault Server.
C:\ProgramData\Autodesk\VaultServer\Filestore\Indexes.
Keep in mind that ProgramData is a hidden folder by default, so you may have to enable viewing hidden folders.
Alternativley, you can take that path above and paste it into Start -> Run.
-Hywell
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17331901&linkID=9261340
P.S. C:\ProgramData and C:\Document and Settings\All Users are the same location (in other words, the path that Hywell mentions is the same as the path in the KB document above)
