Thanks Hywell, So we deleted the lucene indexes as suggested and stopped and restarted following services as suggested. But when we try to login to ADMS console again as administrator it dont seem to do anything. It shows status running but screen is blank. I am attaching the snapshot of the same. So we could not do the second step of rebuilding the indexes again. Any idea what could cause this issue?
All the users are able to login and all property mapping seems to be fine. Error 1013 that we used get while seaching is gone.
Bhavin
_______________________________________________
How To... Delete the Lucene Indexes and Rebuild them
Although the following was part of an earlier post, we have had a number of calls where we needed to give instructions on how to delete the Search Indexes and Rebuild them
Delete the Lucene Search Indexes
Delete this folder:- C:\Documents and Settings\All Users\Application Data\Autodesk\VaultServer\Indexes
To do this successfully you may need to run "Services.msc" then stop the following services
- Autodesk Data Management Job Dispatch
- SQL Server (AUTODESKVAULT)
- World Wide Web Publishing
- Delete the folder, then restart them in the same order.
Rebuild Search Indexes
ADMS Console. Tools>Actions, Rebuild Search Index
