Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Eroor on login
2 REPLIES 2
168 Views, 2 Replies
Eroor on login
Just installed Civil 3D 2007 which uses vault for project management.
On trying to Login to Vault I get the following error message:
Error -1:
The request failed with HTTP status 404: Not Found.
I posted a message in thge Civil 3D newsgroup but no answer yet.
Would appreciate any hint.
Thanks in advance.
Reinaldo
2 REPLIES 2
Reinaldo, try to goto http://
vaultserver>/autodeskdm/services/securityservice.asmx, do you get a
response?
Most likely the ADMS server is not installed. Check in Add/Remove programs
to see if you have an entry for Autodesk Data Management Server.
"R. Togores" wrote in message
news:5211740@discussion.autodesk.com...
Error -1:
Thanks in advance.
Reinaldo
Hi, Thanks.
ADMS was not installed. I thought it should be as I selected the adequate
options on installing Civil 3D 2007.
I believe instructions on installing Vault for Civil 3D Project management
should be more explicit.
Reinaldo
"Hywell Herrero (Autodesk)" escribió en el
mensaje news:5211985@discussion.autodesk.com...
response?
Error -1:
Thanks in advance.
Reinaldo
