Anytime you view a file (outside of the Vault) it will pull a copy down to
your local workstation.
If you want to see the other sheets. RMB... Navigator.. you can show the
other sheets in the set this way.
Bob
"Dave Hoder" wrote in
message news:5077062@discussion.autodesk.com...
Using the view tab or View in Window only shows 1 sheet of a multi-sheet
idw. Is there any way to use the real viewer without retrieving a copy to
the local drive?
Dave Hoder
Product Design Engineer
idX Seattle
www.idxcorporation.com
Using Inventor v10sp3a / Productstream 4.5
