i need help. I searched a long time but i doesn't found an answer.
The connection between the attributes in the AutoCAD-Title-Block and the attributes from Vault is working.
During the Vault-Checkin the Vault-Attributes are filled correctly.
But the attributes in the DWFx, that is published automatically during checkin, are not filled correctly.
Where can i configure it?
Thanks.
Best regards.
Michael
i have an addition:
The Connection between the Vault-parameters and the DWFx-parameters ist working basically.
In our case one Title-Block-Attribute is connected in Vault with the parameter "Kommentar" and most times the DWFx-parameter "Comments" will be filled with this content (at random, without any configuration from us).
Now is the question: What are the internal connections Vault-parameters => DWFx-parameters and on which way can i configure this.
Thanks!
Best regards
Michael
What do you get if you publish using AutoCAD? Vault basically uses the same to publish so it could be some configuration there.
