Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
DWF Publishing
1 REPLY 1
BassEngineer
170 Views, 1 Reply
DWF Publishing
I have a customer who is having problems creating DWFs. Sometimes during check in, a .dwf file of the cad file being checked in is created in the local folder but Inventor just hangs and sits. The only way around this has been not to create dwfs. I also tried creating the dwf inside the vault with the "UPDATE" button, but the dwf doesn't get created. When I checked out the file, and tried publishing manually (in Inv using FILE-PUBLISH) I get the attached error message. Any ideas?
1 REPLY 1
tony.feng
in reply to: BassEngineer
Hi Pernicious,
For Inventor(2009) will hang when checke in a dirty drawing with dwf publish, this is a known issue, a hot-fix for "Progress bar does not get closed" has been released, you can found it in the following URL:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112& #38;i d=11643482&linkID=9242019
(Plese delete the space character in the link to access the website)
Please retest this issue after install the hot-fix, if it still reproducible, please attach your cad file, we will do more research to it.
Thank you for your question!
Tony
