Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
DWF Publishing
2 REPLIES 2
Raider_71
125 Views, 2 Replies
DWF Publishing
Hi all,
Any idee why the DWF publish option is not available ot greyed out in the check in dialogue box from Inventor? When I click on Settings the checkboxes are greyed out.
I checked under Administration in Vault Explorer as well and the publish DWF option is checked. Only the DWF publish folder is unchecked.
Pieter
2 REPLIES 2
tony.feng
in reply to: Raider_71
Hi Pieter,
Please make sure you select an Inventor-file (such as ipt,iam, idw and so on)to execute Check In command in Vault Browser.
If you select *.ipj or non-Inventor file (attachment of Inventor file, doc, bmp, xls...) and Check In, in Check In dialog click "Settings" button, you will see the "DWF Attachment Options" are not available.
Inventor does not support publish DWF file for *.ipj and non-Inventor files.
Tony Message was edited by: Tony.Feng
Madhan_T
In some cases, you need to ensure that "DWF" related "Add -Ins" Load behaviour is set to "Load on Startup" from Tools > Add-ins Manger dialog.
Madhan
Madhanagopal Thiruvenkatachalam
Principal Engineer
Engineering Escalation Team
