When an Inventor drawing is checked into or released in vault, sometimes one of the dimensional text on the drawing appears at a smaller height and its moved (like the text justification has been changed). It appears to be random, but when the drawing is opened in Inventor it appears correctly. If you check out the file again and back in, the issue goes away. However sometimes this hiccups is not caught and it causes problems on the manufacturing floor. Any thoughts?
Vault Pro 2014 with Sp1
No ideas. Are you publishing your dwf through job processor, or one file at a time during check in? Can you post a screen shot of what you're seeing? Maybe this will mean something to someone.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
