Unfortunately, the way those files are named during check-in cannot be
configured.
Would you consider renaming your existing DWF files with the Rename
Wizard in Vault Explorer/Productstream?
Just a suggestion, but if you do a Search[Ctrl+F] for your old *.dwf
files, Select All[Ctrl+A] in the search results, right-click and
Rename... When you get to the Enter Names step, click on the Naming
Scheme button and add ".dwg" to the Suffix: part (uncheck Prefix:).
Afterwards, you should have a collection of {file}.dwg.dwf files. Then
then next time you check in {file}.dwg, you will get a new version of
that DWF to replace the old one.
-Dave
VRACA wrote:
> When I check in the file from AutoCAD with the dwf option
> checked, if the file name is
> 123.45.678.dwg
> the dwf file name is 123.45.678.dwg.dwf
> Is it possible the dwf file to match exactly the dwg file name, because I already have 1500 dwf files created with the previous AutoCAD versions, and this way I will have two files
> for any of those already there-
> 123.45.678.dwf
> and
> 123.45.678.dwg.dwf
> I need to manually check on publish folder every time , and delete the old files..
> Regards,
> Nina
